Each red power wire feeds ONE amplifier board.....That's a little different. What is the logic of two and four wires in lieu of one black cable and one red cable?
No need for 4 negative (ground) wires, as the entire heat sink is a ground......
and each board is grounded to the heat sink in 5 spots.....
AND
Two wires passes twice the amperage. Four wires passes four times the amperage. With high powered amps the amperage is even more important than voltage.
Recon
One 6 gauge wire is not good enough?I did not want to clutter up the amplifier internals with a MAIN power buss bar in order to use the heavier gauge wire you mention.....
The Marine grade battery cable wire I used is more than adequate to drive this amplifier....
User / Operator supplies their own fuses and fuse holders at their discretion....
