That's good stuff and I appreciate it.Eldorado828,
I feel your frustration!
Yes, you may have a shorted component that goes from the B+ line to ground, but because this is a Texas Star amp there is another very common possibility.
you may have a component lead on the underside of the board that is too long, or one of those washers that go underneath the board may be shorting the positive trace to ground.
since you know that its before the power switch, that narrows the areas you need to look at.
you're going to have to take the whole amp apart again and remove the PC board and look everything over.
get a small file or other similar implement and file down any component leads on the bottom of the board that look suspect (too long).
also, either glue or solder those washers right to the bottom of the PC board so they won't move around on you when putting the board back in.
its a pain in the butt but welcome to working on Texas Star amps!
hope this helps.
LC
I haven't been back to it yet but hopefully by the weekend.
I will say, when I had it apart the first time I actually did glue the washers and trimmed anything that was sticking below the board for that very reason because there was a lot of reflowing involved. The board had a very minor warp to it so I even added some thin foam spacers in a couple of areas where it kind of just floated or didn't have anything for spacers.
I was pretty meticulous when I put it together but it has crossed my mind that something might have gotten underneath the board.
Keep in mind, the amp was working well and had been under use for 3 hours or so on and off. That's the reason I stray away from the thought of a short underneath but it isn't impossible.
Once I'm back on it I will report back.... but complete disassembly isn't out of the question.
