I had a friend drop off a Texas Star DX-500V for me to look at. The problem I found was the power trace that runs on the underside the front switches of the PCB was blown. I repaired that and the amplifier now turns on. I then proceeded to manually key the amp. The relay keys but the meter lamp is not turning on, which means I have no DC bias on that red wire to turn the transistor base on. Can anyone help with this? The power switch seems to be functioning normally. Thanks in advance
