Tram D201 ssb hum in receive
klj2497
222
47
38
63
There is a hum in ssb receive. i have replaced the four C624 capacitors, the c5 can and c517. Im stumped
klj2497,
Just a few quick observations-If you have "been there, done that" please ignore.
If hum is in SSB RX only, I would look strictly at the SSB/RX signal path. Perhaps a diode or tube active in SSB only?
I would assume (never been inside a D201) that power supply rectifiers are the same circuit in AM as well as SSB but if not, a bad rectifier diode in the power supply?
Noise blanker circuit/tube?
If the hum can be "squelched out" it suggests that the noise/hum is in the IF strip of the SSB RX? Could be a weak or "noisy" tube??
Good Luck. I'm a sucker for the old classics!
David
The hum can be squelched out by turning up the squelch knob.
This is a long shot, but try tapping on the tubes (with something plastic) while the Tram is ON to see if it changes. I had one (long time ago) and did the tap-tap-tap procedure and found the culprit tube (I thought).... LSS - it was the tube socket.
Thank you, for the replies. i will check the, v500, v501 and v502 tubes. I love the tube sound.
