Tuning Pulser... Pecker, or Whatever?
Mudfoot
Elmer
Jun 17, 2009
11,295
6,711
698
64
Southeast Ohio
OK, I'm intrigued about using one on my amplifier. I see them for sale. I read articles about them. From what I've read, they are beneficial.
Well? If they are so great, then why can't I find a YouTube video of one being used?
I did see a video on how to make one. I just want to see one in action.
Beneficial depends on a couple of things. How long you take to tune an amplifier. If you can do do it in a couple if seconds I don't think it's beneficial. If the tube(s) in your amp are truly adequate for the job you can take several minutes to tune up and not stress anything.
Once you know where the load setting is for each band you can repeak the plate at reduced power if you move around. If you still want to verify the settings all it takes is a second at full keydown to check the meters.
I was concerned about getting an accurate grid current reading with the pecker. The W8JI blurb answered my question. I would not waste time or money on one.
http://www.w8ji.com/loading_amplifier.htm
Reactions: Mudfoot
Yes, I read Tom's article, beforehand.
I'm still puzzled, why I see no videos on it.
BTW, Tom has a Facebook group on Ameritron Amps. Very good resource. He's very active in helping people out.
I was reading something about that. There was mention, that simply doing the dits, was not adequate. I can't recall the whole article. I am not wanting one one these, just curious why there little anecdotal posts.
Basically you press dit paddle on your CW key and voila.
Mike
The idea is to tune at full output however, full output places the amplifier under stress in the tuning condition. To remedy that problem, they reduce the duty cycle of the carrier by pulsing it. The biggest problem is those pulses need to reach the same power level as your highest word peaks will and you really need a peak reading watt matter otherwise your just tuning the output stage to match 50 ohms at an average power level at the sacrifice of peak watts and efficiency.
Another thing that has been pointed out is the grid meter (and plate current) will only be showing the much lower average, pulsed grid current during this type of tuning. It's usually noticeably higher during normal operation with a carrier or word peaks. If the grid is too high, you will need to back off on the load and re-dip the plate current back into the resonant null. If that fails to keep grid current within reasonable levels, it's likely the amplifier is being overdriven. Exceeding grid or screen current will get you into trouble faster than exceeding plate current or dissipation (unless your blower sucks).
Reactions: Slowmover
  • @ heartbreaker3473:
