So I upgraded from a quad 6 to a new quad 5n2. I made an RJ45 to 4 pin adapter cable for the new radio - and wanted to use my favorite mic on the new radio - my Turner +3. I have used my turner +3 on my quad 6 fine- I love it. (also with an adapter cable I made)
Well all my other mics, realistic power mic, d104 mic - work fine with the 4 pin / RJ45 adapter cable for the new radio - but not the turner +3. I even tried a turner +2 - and same - no go.
When the turners are hooked up and I press the talk button nothing happens on the radio - it just receives....and when I flip the bottom switch on the turner the radio goes into transmit mode (without pressing the talk button on the mic) - but no modulation - when I press the talk button the radio goes into receive - weird.
I know turners are different than standard mics. I checked the white wire in the mic cord in the base of the mic- it has an electrolytic cap on it - I removed it and put in a 104 cap - but it makes no difference. Neither does switching the radio between dynamic & electret.
I have double & triple checked the adapter cable rj45 to 4 pin that I made - with the stryker reference diagram on the net - and am 99 % sure my wiring is fine.
Anyone have any suggestions ??? Anyone else seen this issue with the new anytone ?? Anyone else tried a turner +2 /+3 on the new quad 5 ???? I'd love to get my turner +3 working with my new radio - but so far no luck - and I don't know why.
