Turner Super Sidekick Again
357magnum
Feb 25, 2014
2,367
3,253
273
72
Coventry RI
Sorry but by now I'm grasping at straws . I cleaned the contacts , put a fresh battery in an took the plug apart an found 1 strand of frayed shield wire an thought I found the issue . Nope plugged it in to the 2000 an it distorted my audio .??? The only thing I found is mic wiring I found said 5 wires this mic has 4 , I assume the yellow wire is in the cable although I don't see it .Any suggestions would be appreciated .At this point I'm relay to shelf it . The person I bought this radio from CLAIMS he was using it .Just glad I have My Silver Eagle that works fine . Thanks
Sent from my NB09 using Tapatalk
Thank I did at this point confused almost like its not wired right but the guy said he was using it .( which I find had to believe )
If its distorting the receiver audio then it sounds like it is pulling power from the radio. Cut the plug off and wire it up one wire at a time plugging it in to the radio each time. By doing this you will see which wire is causing the issue.
