Unexpected Interesting Reward!
Dmans
Jan 22, 2017
1,478
1,986
173
Georgia
I wasn't expecting anything in return for my recent efforts on a friends 148GTL-DX but he surprised me with a Shure 444-Demco Edition microphone. He told me the element was no good in the microphone but I have a plan and a fix for that. Pictures to come!
73's
David
Below are pictures of the Demco-Shure 444 microphone.
And here is my cure for bad microphone elements.
Above is an Adafruit product. It is a model “MAX 9814”. I have installed one of these in the stock microphone of my 980 SSB and it really woke the radio up. In the 980 it is powered from pin 6 of the stock mike jack. I did have to replace the cord on the mike with a cord with 5 wires to make it happen but it is worth the effort.
I installed one of these in a friends Turner Plus 3 ( I call it a Turner Plus 3 +) to replace a bad element and it made a world of difference!
The Adafruit Max 9814 has a built in AGC circuit as well as programmable output (via jumpers) for 40, 50 or 60 dB gain. I have found that 40 dB gain is more than plenty and have used a resistor in series with the audio output to avoid over driving or squeal. The resistor value has been determined by trial and error. I believe the resistor I used on the 980 SSB was 150k ohms.
For about $8.00 it’s hard to beat!
Happy experimenting!
73’s
David
73’s
David
That's a neat little element, I am going to get a couple. I wonder if a 9v battery would run it? I have an old Galaxy hand mic this would be perfect.
Shadetree Mechanic,
A 9 volt battery does a great job. That is what powers the unit in the Turner Plus 3 +. I powered it from the 980SSB mike socket because the voltage was available and the hand mike was small. I did use a dropping resistor to get the voltage down around 5.5vdc on the Turner and can't remember what voltage the 980SSB unit is running at. It seems the unit will operate from 3-9 volts but I can't recall for sure. You can find the specs on Adafruit's web site or Mouser Electronics. Audio frequency response is very wide as well.
73's
David
I checked out the specs and it is capable of putting out several volts. I wonder what would happen if this was used to direct inject a radio? The AGC might work out perfectly. Maybe with an attenuator to dial it in. Now I am thinking....
(y)
The AGC does work well. I have not messed with the "AGC recovery" timing but the microphone element is sensitive and even with the 40db gain jumpered you will probably still need a resistor in-line with the audio lead to cut it back some. I have not installed one of these in a desk mike with a gain/sensitivity potentiometer (the Turner Plus 3 + potentiometer was defective so I bypassed it) but the Shure/Demco will be the first one I will try. It will still need an in-line audio resistor I am sure but wiring the pot in-line with the audio lead should allow some restriction in the audio power as needed.
A cheap, fun, useful project for sure!
73's
David
David
I might try this but, I find your last sentence confusing. If the 980 is already a 6 pin cable stock why go down to a 5 pin?
