Uniden grant xl echo board removal
The two wires passing between the RF output and its ground return might couple some RF into a sensitive area.
I would get the wires out from under there and move all wires as far from the RF output as they can be.. Those wires are also sitting right on a coil. Probably not the cause of the talkback though.
Reactions: MKwrench
That is exactly what’s happening here, if I unplug the mic with an antenna connected I still get receive even with the volume turned down fairly low. As an experiment I tried that with my other two 148 gtls and I have to turn the volume all the way up. To hear even a little bit of static coming out of the speaker. The only problem is I don’t see any obvious resistor going from the barrel of external speaker jack to ground.
This radio has experienced a reverse polarity event, some time in the past. D55 looks like it burned completely off the top side of the board. D44 has been replaced, and it burned open the trace on the board, you can see where it was repaired by someone in the past with a jumper wire. I can’t tell if they replaced d44 with a zenner diode or an 1n4148. I’m not too worried about it for the time being. The end of the large red power wire that goes from the back of the board to the front on/off switch was charred and melted but ohms out good, so I desoldered it and slide some heat shrink over it. When d55, which is right under the power jack burned up, there was a bit off a fire back there. The insulation on the external speaker wires is charred as well as the three wires going to the cb pa switch.
No it’s not, it kinda looks like it in the picture, that’s a little bit of the lead of the talk back resistor that I clipped out. I corrected the wires that were passing under the antenna wire. I’m thinking about pulling c168 a ceramic disc cap and testing it. I’m looking at the schematic. It looks like the barrel of the ext speaker jack connects to c168, c240, c167 maybe?. And a wire that goes all the way to pin 3 of the mic jack.
This radio hasn't been converted from the original 5-pin mike socket to a 4-pin socket, has it?
No it has not, it’s still the original 5 pin socket. Today I even removed it, so I could do a good visual inspection of it and the pcb it’s mounted to. I even removed the dried Sony bond glue on l503 and 504, on the little mic jack pcb. I also removed the front faceplate and knobs. so I could remove the cb/pa switch and inspect it, make sure nobody put a resistor in there or anything crazy.
It may be hard to see in the pictures, but the wires that go to the internal speaker got charred, along with the three wires that go to the cb/pa switch, and two wires that ultimately go to mic jack. The out side of c167 is blackened. This all happened before I got the radio, I’m assuming it happened when d55 burned up. It’s almost like the was a small fire back the lol. But none of the wires seem to be shorted together, or are even touching.
At this point all I know to do is properly repair all the burned wiring and pull c167 and test it, and maybe some more of the ceramic discs.
I fixed the burnt internal speaker wires, even though the insulation was not burned off, and they ohmed out fine. Next I pulled c167, 168, and 169 they tested good on a little transistor parts tester, they measured well within 10%. I went over the schematic trying to reconfirm, that I had reconnected the wire they had cut on the mic gain pot, in the right place. I have continuity from it all the way to pin 1 on the mic socket. They had cut the wires that go to hi low tone switch an I reconnected them and it works. I pulled q53 and it tested good so I put it back in, I’m thinking about testing q43 and q47 also. I’ve got it inmy head now, that this problem is a failed component. But I’m far from a radio technician, but I’m not giving up. If I spend enough time on it, I will fix it.
So on this radio, if I have my antenna connected, with the mic unplugged. I get real receive audio out of both the internal and external speaker, just not really loud.I can actually hear stations on channel six. If I plug the mic in it gets loud like it should be.
I plan on checking some more disc caps, and changing some of the electrolytic. I still need to check the little disc cap on the mic socket pcb.
Does anyone think a failed transistor could be causing this problem.
I’m editing this to say that, with the mic unplugged I get receive audio out of both the internal and external speaker at the same time, when I plug a mic in I get loud audio out of just the external speaker.
I wonder if the external jack is shorted to the case or something, pull the wire that goes to pin 3 on the mic jack and see what changes.
Without it the ground side of the speaker and ext jack should be open nothing should be heard at all. If you still have sound or talkback follow the trace that wire goes to and look for anything shorted on that path. If not it should be on the mic jack board. 1st try seeing if the pin 3 line ungrounds or opens while keying the mic and go towards the mic from there.
Someone double check my thoughts here.
Edit: Nomad just suggested that right above, I didn't see ...
Looking from the speaker, towards the audio amp there are blocking caps and towards the mic it should be open while PTT is pressed. We should test that.
With the radio OFF, first ohm between one of the speaker terminals and board ground with PTT released (RX). You should see either 0 ohm or the speakers dc resistance (depending on which side of the speaker you ohm). Now, with the ohm meter probes between ground and the speaker terminal that showed 0 ohm, key the mic (radio still OFF). The resistance should rise rapidly.
Keeping the mic keyed (tape it down if you have to), allow some time for the ohm meter to charge all the associated capacitors and let it settle before reading. Once it settles, see if there is an open circuit or a very high resistance. Thats what we want, an open circuit or, at the very least, a high resistance from capacitor leakage, but not a low resistance.
If you see a lower resistance between the speaker and ground with the radio off and PTT keyed, a problem exists. Write down that resistance.
Since the speaker seems to be getting ground even with PTT pressed, I would be interested in knowing where the ground side speaker wire goes. Did the wire that should find ground via the mic get moved to a different ground?
Reactions: MKwrench
Ok I have finally got a little bit of time to mess with this radio again. I will try disconnecting the wire going to pin 3 of mic socket and seeing if that stops the talk back.
With the radio powered off. The internal speaker connected. And a coffin style mic plugged in. Dmm set to ohms, one lead touching the back of pin 3 on the mic socket I get 8 ohms touching the other probe to the white wire of the internal speaker, and I get like 20 ohms if I move that lead to the brown wire, nothing happens if I key the mic, the readings don’t change on either speaker wire.
One thing I did notice, if I connect one lead of dmm to board ground disconnect the internal speaker wires touch the other probe to the brown wire and key the mic it seeming brakes ground going to the brown wire, and I get ol. Which seemed like a good sign to me, but when I try it with the internal speaker connected, it does not make the brown wire going to the speaker go open.
Brandon I attempted to carry out the tests you described in detail. But so far I have never found one of the internal speaker wires showing only 8 ohms or ol or 0hms, with one of my dvom leads connected to board ground, and the other lead connected to either speaker wires. As far as them messing with mic wires and where they ground, the only mic wiring that I can tell they ever messed with was the left wire on the back of the mic gain pot that goes to pin 1 on the mic socket, they had cut that wire and were feeding the echoboard into it.
I know this sounds dumb, but what should I do to rule out that the ext speaker jack is not shorting to the radios chassis? I know that there is a leaf spring switch contact in it. And with the radio powered on, if I push down on the contact I loose all receive.
If I touch one lead to board ground, and touch really any metal part of the external speaker jack I get continuity. With the switch in the cb position. If I flip it to the pa position I don’t get continuity when touching the barrel hole part and then touching the spring.
I’m going to mess with this radio some more and report back, I’m still checking something’s out.
The schematic shows the external speaker jack on the hot side of the speaker so any short there would load down the amplifier, not provide the speaker with ground.
One of the speaker wires should be wired directly to pin 3 of the mic jack. Unhook that wire from the speaker and ohm between it and ground with the mic open and then again with the mic keyed.
