Uniden pc122xl no tx or rx
Hi
Checked voltage at ic4 and have 13.5 at one pin and 8 volts at the other also i have no way of checking frequency at the pll do i need a scope for this measurement also no popping when radio is powered up no volume with squelch down at max volume its like its not switching between pa and radio but i checked the switch and it seem to be switching when i did a continuity test at the solder connection i replaced two 1000uf 25v caps next to power supply one was faulty maybe other caps need replacing radio didnt die whilst transmitting i put radio into moth balls and the next time i turned it on nothing
Thank joe
You should probably have at least an oscilloscope, frequency counter, and DVM for radio repairs. Add a frequency generator for alignments.
In this case, though, if it was working before you put it in storage and now it's not, I'd start looking at recapping the radio. Hopefully it's just a bad electrolytic and nothing else got taken out. Site member Klondike Mike sells cap kits: https://klondikemikescapkits.com/co...65-uniden-pc-122xl-electrolytic-capacitor-kit
Also, if it has some hardened brown glue in it, you'll want to get that stuff out. It gets corrosive and conductive and can eat the legs off of components.
Gday
I have a dvm,freq counter several radios watt meter dummy load what i dont have is an esr meter to test caps incircut without replacing all caps and no oscilloscope but im willing to get one any suggestions!
Thanks joe
Gday
Not much glue was used in this radio just a bit around the caps i replaced no corrosion anywhere in the radio i think maybe caps that have degraded in storage just a guess
pc122 troubleshooting thread with no tx/rx:
robalo mentions in that thread:
"C101 - takes out AN612. Kills 1/2 the IF for anything AM or SSB..."
Have you contact/circuit board cleaner sprayed everything/connectors etc and just check for dry solder joints. Could also have the radio running and feel around with your finger, see if RX comes back by lightly prodding/flexing the board and its components (highly technical....) which may give away a dry solder joint problem.
Reactions: Robalo
Gday
Tx light doesnt illuminate! replaced c101 still nothing im still to check voltages on pll ill post back when ive carried out those measurements
Thanks joe
It's extremely difficult to fix anything without the proper tools. It takes years of experience to tackle two-way radio repairs properly, and with confidence. Asking people questions on the Internet is not the way to do it. Get some books and start reading.
Gday
The internet is a wealth of information and i believe somebody here can help
Eg a friend of mine is a mechanic we have a electrical problem with the car taking out the headlights we need lights to drive home 2 hours there is a short in the wiring but where is the short within 5 minutes of dr google we were on our way the short was under the car rubbing against the exhaust when its a common fault it usually affects all cars in that line
Also a have a few book lou franklins understanding and repairing cb radio
Amateur radio handbook
Because i have limited test equipment i am here with my fellow radio operators after a hint
Thanks joe
Is the VCO voltage in check? It might just be out of lock. I think a failing channel switch can do this also by creating incorrect pin combinations. I feel we should hear a small POP when the power switch is cycled, so be prepaired for multiple issues. (or do they fully mute, out of lock?)
I find poor solder joints in these all the time too, especialy after sitting for a long time.
Here is the TRC465 manual, Its a "close enough" cousin to the PC122. Hopefuly you get it figured out, these are great radios...
Reactions: Robalo
You can use a different receiver to sniff for the IF signals. We are mainly curious if the oscillator and VCO signals are present, not what they look like. You might be able to see if the radio is responding to the PTT by monitoring the current at the DC input. If I disconnect the driver and final in my washington, the current still goes up by about 110mA when I key. Electrolytics usually fail open, so touching a good cap to a suspected cap can help find dry ones. If many are bad, this may not bring the audio to life, its just a simple test that sometimes pays off.
Gather clues. Start with another receiver.
Gday
I do hear a tiny pop when i power on but no volume even at max,squelch is set to minimum checked mic with multimeter and its switching checked pa with external speaker no audio,no tx light,checked cb/pa switch and it working,when i key the mic theres nothing like its not even there tried jumpering mic jack nothing in any combination today i pulled a transistor pnp 2sb753 thinking it was faulty but it checks ok
Just be gentle with me as i said at the beginning i have limited electronics knowledge the only component ive found that was faulty was a 1000uf 25 v electrolytic cap one of the two main caps i have no voltage readings from the pll as yet but i ll check them tomorrow got sidetracked with tr544 i thought it was an npn but it was a pnp
Thanks joe
Hi
Pin 15 16 of the pll (ic2)voltages show 5 volts at first and then drop to 3.5 volts like its unstable it seems like theres an issue there
Thanks joe
