Uniden pc122xl no tx or rx
Only thing that comes to mind that it may be the transistor in the back of the radio near the power connector. You can use a TIP42 in place of it. Unsure if that only deals in AM and not the SSB side of things. Even if it doesn't fix it, it is a good idea to replace it from what was there originally.
  • Haha
Reactions: sp5it
Gday
This is the transistor i pulled its a toshiba 2sb753 checked it with dvm and its working im guessing it just a bad cap finding it is a different story i was thinking of an esr meter so i can test them all in circuit
Thanks joe
Hi
I have found no voltage at pin 16 of pll and ic5 has 6 volts at pin 6 so i think the ic5 is working im still to track down the missing voltage some other component has failed any ideas
Thanks joe
I did this on a hunch with a simular radio.
Find test point 2 and measure voltage to board ground/ not chassis ground, on channels 1 and 40. Remember the number on 40, while keying slowly turn L13 to its max top and bottom while watching your watt meter for movement. record max and min voltages, or the voltage that lit up the watt meter. sometimes the specified 4.5 0n 40 isnt enough...
Gday
Have found both pin 15/16 of pll has no voltage and channel display is missing segments like theres not enough voltage there to power the display
Thanks joe
The missing segments could be from a dirty channel selector.
You mentioned before that it doesn't seem to switch from PA to radio but you had checked the switch was working with a DMM.
When you switch to PA do you loose your channel readout like your supposed to? and likewise do you get your channel display showing when switched back to radio?
Have you tested PA (and therefore microphone) by plugging in a set of headphones into your PA jack, key up and hear yourself talk? You may need to turn your volume up.
I know you said you have checked the mic but how did you do that? Have you another mic you could try? Have you checked the mic socket wiring in radio is still intact etc.
Gday
I have tried pa with external speaker plugged into jack and nothing,im missing voltage on pin 15/16 pll i dont lose channel display when switching between pa/cb should i ! also missing 5v at base of q32 ,tried different mic no difference still no tx or rx pll wont work without 5v at pin 16 tried swapping the pll thinking it was the problem but problem still exists
Thanks for taking the time to respond
Joe
Gday
I dont lose channel readout it stays on regardless of cb/pa switch position this must be the issue, i only did a continuity test on the switch and its switching but most likely no power being supplied
What's the voltage on pin 1 and 3 of IC4?
Voltage on Pin11 of PLL?
Mike
Mike ic4 voltages are good checked against another pc122xl have checked voltage on pin 11 just cant remember if it was below spec ill get back to you on that one
Thanks joe
Apologies.I have bummed steered you that one, I was getting it mixed up with ch9 taking the channel readout away. I'm just a beginner too trying to help.
I asking those question because just feel it could be related to the mic or mics path and really make sure that's right before looking for actual circuit board problems. So can your hear yourself on PA? That shows the mic and some of its circuit path is working. You should try an external speaker while on RX as well.
Does your PC122 have a mic socket on the circuit board like this pic below. If so check those 4 solder joints. Sometimes they can have dry solder joints from the mic plug being pressed in:
Gday
Voltage on pin 11 of pll is 5v pa/cb display doesn’t change regardless of switch postion tried on both pc122xl the working and non working the mic socket looks fine i have the facia off pa doesn’t work at all my problem is voltages missing at 15/16 of pll and q32 pulled transistor and its a npn and it checks ok some component must be pulling voltage down to ground i’ll check path on the schematic and see what other components are on that trace
Thanks joe
Gday
Thanks joe
Since15 is LD and 16 is an unbuffered copy of LD (according to the image on radiomods) and locked is 1, the PLL is likely unlocked as you have the expected 5v at pin 11 and not at the LD pins.
LD is also tied to the channel selector, could explain the issues there.
Look for a missing LO signal, could be a dead oscillator.
