Wanted to buy Uniden Grant XL mode Switch
They sell both a single-deck 4-pole, 3-position switch and a two-deck version with 8 poles.
The 148 might get away with the single-deck one with 4 circuits. But a Cobra 2000 needs more than that.
Could be the simpler one will work. Just be sure to copy any pics on the sale listing that show the internal hookup to the pin numbers. Won't always be numbered the same as the original switch.
That is, if the original switch has any numbers on the lugs.
Reactions: NZ8N
Here is the two-deck 8-pole switch For the single-deck version, just use the top half of the schematic.
Hopefully Nomad reads this or somebody way smarter than me. I am getting ready to install this switch and I am totally lost.
Whoa! Forgot the mode switch in that model is on a pc board.
First need to identify the 'common' pin for each of the original four circuits on the original switch. Those will translate to pins 4, 9, 13 and 18 on the new one.
Identifying which pin is USB, AM and LSB on each of the four circuits would be next. The wires would have to be cut from the pcb-transition connector, stripped and soldered to the lugs on the new switch.
Naturally testing for continuity to do this may not work if the switch is bad. If it has one good section, the pattern for which pin is which mode should hold for the other three sections, though.
Not quite a chinese puzzle, but close enough.
At least the old one is arranged as four sets of four pins.
Reactions: NZ8N
It would be a stab in the dark, but I would remove the switch from the board and pray the terminals were numbered. If that didn't work it would be time to reverse engineer the whole thing.
