Weird problem with NB - works as AM detector
sp5it
Master of puppets
Jul 9, 2009
2,775
3,743
273
Poland
www.qrz.com
Hi. I got the problem with one radio.
When NB circuit is on I can hear stations talking on the other channels in a few hundered meters radius weak but clear - nor dependent on rfgain position. It is working as AM detector.
When NB is off they are gone.
Anyone had similar issue? Ths NB circuit is very common for most SSB chassis.
How to get rid of that?
I tried to use diffrent D1, D2 diodes but no improvement.
Mike
Because the noise blanker compares the average noise around your frequency to the noise on the actual frequency to determine if blanking is triggered, they often have problems dealing with strong signals. Strong on frequency signals can sometimes be distorted and strong adjacent signals can "bleed" right trough the noise blanker. The better circuits have an adjustment to set the blanking trigger level. I didn't see that in your schematic but it sounds like the blanker may be too high. In either event I wouldn't expect good NB performance with adjacent stations transmitting within a few hundred meters of you.
