What are your thoughts on the VHQ Hexbeam
The bamboo I think the author got the poles wet and bent them slowly to form the curve then painted them to hold the shape then installed the wires. My memory isn't like it used to be.
I'm not certain your location but if you want the one I have it's free local pick up. Not going to ship it. The hub is the DX engineering cast aluminum hub the spreaders fasten into.
will most definitely be painting the spreaders before this thing flies. I'm anticipating yearly or so repaints.
Look into marine grade fiberglass paint. It should last longer than most other paint.
I have a Lightning Bolt 5 band quad. I just took it down for a few repairs after 15 years or so. It has fiberglass spreaders and they have a pretty rough finish. They were just really dirty so I used a pressure washer to clean them up and they look almost like new now. They were never painted. There are a few fiberglass threads that have popped up here and there on them but it was kinda like that when new anyway. Looks like they will be good for many more years. All the other parts are still good.
Here is a picture of a spreader half cleaned. It all came off easily. The pressure washer is about 1600 PSI, about the same as at a self car wash.
Reactions: Crawdad
Thanks much for that info, much appreciated. Hope to be here long enough for them to need replacing.
7 3 sir
Reactions: Hurricane145
That DXE hub is a serious design and I thought about homebrewing a hexbeam around one, but I decided to take the easy-antenna way out this time and bought the KIO model instead. It's plug and play, something I'm not used to doing since I usually homebrew, but I ain't getting younger.
7 3
I am looking at this Hexbeam again. After moving to a new QTH the 80m dipole just is not enough to fill my needs.
I ended up buying the KIO HexBeam and a Yaesu G-450A rotator. Very happy with this set-up. 100+ DXCCs worked since putting it up last year. No amp. It has stood up very well to sun, snow, rain and wind. Zero issues. The folks at KIO are quick to help with any problems. They redesigned the center post a few years back to use a single piece T6 aluminum tube that runs thru the hub and clamps directly to your mast. Very strong.
7 3
I don't know who makes the best one, all I know is, they work really well. I have heard so many IC-7300 and hex beam combos on the air that I joke that the dealers must have all ran a super deal on them.
Reactions: BenMara and Crawdad
I guess if "best one" means heaviest duty components then you probably have to look at VHQ or G3TXQ in the UK. Maybe the DXEngineering kit also. RF-wise they must all be fairly similar.
No 7300s here, you gotta be able to hear 'em to work 'em.
7 3
  • @ Hambones amps:
