what is required to talk on 10 meters
radioreddz
Nov 20, 2005
367
105
53
so. maryland
want to get ready for when the band totaly opens up. looking to be able to talk on 10 meters. what are the requirments. i know they droped cw testing is it a general class that allows 10 meter voice. :?: :?: :?:
KI4MSJ said:
You don't have to be a plus. Get your Technician Class and that's it. Digital is 28.100 usb-.300 usb, voice 28.300 usb-.500 usb
And CW is 28.000 to 29.700, although it's usually found between 28.000 and 28.100. Just because it's not required for getting a license any longer doesn't mean it isn't used.
You don't have to be a Tech either, but that is the current entry level class.
Look fellas the man asked a simple question :P
Radioreddz ALL YOU NEED IS A FCC AMATEUR RADIO LICENSE ENTRY LEVEL (TECHNICIAN LICENSE) WHICH WILL GIVE YOU 10 METERS 28.300 THRU 28.500 VOICE ONLY. ALONG WITH ALL VHF/UHF PRIVILEGES. Good Luck &73
thanks guys for the info. just want to expand when the band opens up. voice on 10 meters is all i want,it will give me the ssb dx fix i need. :wink:
No no no...28.0 to 28.5, just like I said the first time! I even provided a link!
This is the Band Plan
28.000-28.070 CW
28.070-28.150 RTTY
28.150-28.190 CW
28.200-28.300 Beacons
28.300-29.300 Phone
28.680 SSTV
29.000-29.200 AM
29.300-29.510 Satellite Downlinks
29.520-29.590 Repeater Inputs
29.600 FM Simplex
29.610-29.700 Repeater Outputs
With A Tech License, You can use
28.000 to 28.500 ONLY!
With a Tech Lic, you can not go above 28.500.
200 watts Max power
28.000 to 28.300 is RTTY/CW ONLY
and you should follow the band plan above.
28.300 to 28.500 is Phone(SSB ONLY)
so to TALK (phone/SSB MODE)Yes it is 28.300 to 28.500.
And CW and RTTY below that.
28.200 to 28.300 is for beacon use.
as asw said a tech can only operate 28.000 -28.300 rtty and data.28.300-28.500,ssb phone(200 watts max) as per the arrl band plan. www.arrl.org on 10 meters. but vhf/uhf and 6 meters you get all modes.hope this helps good luck.
I like PSK31...not RTTY
28.120 to 28.150 -- PSK31
go all data under 28.3 on 10m
