Who knows what this is called?
AOER Silver X-Key Repair Tool Destuffing for Two-Way Radio Walkie Talkie Motorola GP-300 GP-88 GP-328 GP-328plus Puxing PX777(PX-777) PX-777plus PX-328 Baofeng UV-5R WOUXUN HYT TYT PUXING Radio
On Amazon
Well I'll be damned... I believe that just might work... that's awesome, I'll definitely try it. Thank you so much!!!
if i knew where that other1 is id gladly send you 1
I know you would buddy, I was just running my mouth though.
as you know we are miles apart but as always we got each others back.
actually several here on this forum that come to others rescue,not seen as much elsewhere
Ok, if you remember A Christmas Story, when the lamp came.... Hot damn it's here, it came it came it came....
It don't fit.
It's a nifty little tool though, I'm sure it'll fit something else but it doesn't fit the AnyTone AT-6666 controls...
<insert audio here>"back to life...back to reality..."
There must be a couple sizes of those things.
"Que the sounds of a grinder"
Now you need a thin wall socket to sacrifice.
And I shall, oh yes, I shall.
Reactions: Rwb
copper tubing be easier to grind or even conduit. copper tubing has many sizes to get that right fit.
cut it then bore hole through the tube at top n slide a phillips screwdriver in for traction
Reactions: NightThumper
Well that tool is close, maybe modify it? I still think it’s worth buying cause you’ll use it somewhere else.
It’s a mouseketool we’ll use later… hahaha
thats a doohicky tool used to adjust the thingamajigger mounted on the gizmo that runs the doodlewobbler that processes the fine tune on the whackerbill
Reactions: Slowmover
That just popped into my head, I watched a lot of that annoying cartoon with my little girl when she was 3 and 4.
Nothing can process the fine tune.
Copper is real soft, not sure the tabs would be strong enough to tighten without sheering off.
We used to make copper gaskets in steam service at the plant and it softer that you would think.
