Mobile Wilson 5k Water in Coil
When Dinosaurs roamed the Earth they were made from Mobay plastic and I have one that is from 20 years ago that is just like new the base is what needs repair.
I normally drill both ends of a crack.
The Permetex will not hold up long term it is not made for UV exposure I do not believe. Epoxy it sane it than paint over it.
Be careful with dielectric grease it can get in the way of rf ground and the signal propagation.
I used to wax mine a few times a year. I figured the oils and distillates in the wax would keep the plastic in good shape and wax and UV protection helped it as well.
I got a piece of crap chinese willy 5k here too and the match shifted up to around 28mhz. Today I was checking it over and water was dripping around the bottom like yours. we used to take the whip shaft off and put a o-ring on the stud and thread the shaft back on. also yours is missing a rubber washer on the bottom like mine was I noticed. I got a white willy 1k that needs a long whip than what came with it so I stole the washer off that.
all this stupid junk is getting hard to find and shipping a whip is just asking to be raped
