It appears this amp is indeed working as it should,I don't know if the amp was mislabled or someone added the extra driver pill,I'm thinking now it was added.I pulled my tnt in the car,and put this in its place to test,with a three watt deadkey from my 2950 my meter is showing about a 425 or so deadkey,and swinging to about 950 or so.Does this sound about right for a 2x4? this was with amp dial on max. Open to all trade offers.I am not going to keep this amp because my power supply in the house won't run it,and I am very happy with my tnt.
if you look at the picture close you can see the extra driver was added all the screws are silver but those 2
Looks like one circled in pic. You can also see soldering on the 2nd driver pill not like the rest of them so that more than likely is a X model originally.What resister is that? I'll pick one up and replace it
if its violet it is a 470 not 480 8 would be gray?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
