Yaesu ft 891 portable on 12v
KD2GOE
May 30, 2013
952
220
173
45
Buffalo
Any one run the Yaesu ft 891 on a lead acid battery for portable I have a big deep cycle But I want to know how the radio behaves when the voltage sags down to 11.5v i know a lot of the radios are more happy at 13.8 I have seen and had some radios just not like running at 12v they start acting funky ¯\_(ツ)_/¯
My end game is to use a some thing from bioennopower like a 12V, 12Ah LFP Battery and switch betwen two of them.
Reactions: Mudfoot
I think its not a great idea,seems like when you took your test its in the questions
i know about the 13.8 +/- 15% on the paper work what i am asking is real life use things are not always the same as whats on paper.
it tells you that it draws 2 amps on RX the tests people have done show 1 amp
i was asking for real world not what was on the paper work...
well i ordered the FT-891 it will be here in a few days...
maybe next year or 2 ill oder the bioennopower like a 12V, 20Ah after i save up..
https://www.bioennopower.com/products/12v-20ah-lfp-battery-pvc-blf-1220a people are saying they work grate and there useing them on that radio..
Reactions: Rwb
Those current specs are typically worst case conditions and for the RX are typically done at 100% modulation and full output from the speaker which will tend to increase figures to pretty near spec however nobody generally runs the volume wide open at that level.
Reactions: Rwb and KD2GOE
http://www.westmountainradio.com/product_info.php?products_id=battery-boost&navcode=/fpBoost
When the voltage from a battery drops, the Super Booster brings it up to a level that allows for optimal transmit. The output level can be set by a trimmer pot to any value up to 15V. The advantage of using the Super Booster is that a Lead Acid battery is rated in Amp-Hours for use down to 10.5V. However, radios require at least 11.7V to transmit. That results in over one-third of amp-hours in the battery that cannot be used for transmitting without a booster.
Reactions: Rwb
    boog351 has left the room.
