YAESU FT 897d Audio Modifications ?
Have you tried the Palomar SL41 yet?
No Sir. Had to look it up. It appears to be a nice noise cancelling mic. I don't use noise cancelling mics in the base station. They just aren't as loud and punchy sounding in that setting IMO. I do have to use a noise cancelling mic in my big truck due to diesel engine noise. However, I hear folks on the air that could benefit from a noise cancelling mic in their base station due to excessive amplifier cooling fan noise, haha.
https://www.palomarelectronics.com/product-page/palomar-sl41
Reactions: rabbiporkchop
What you can do with most rigs is use the data input on the back to connect your rack gear. I recommend that you use an isolation transformer between the rig and audio gear.
You will probably have to change some menu settings to switch the am/ssb audio input from the mic jack to the data plug. It still won't be wide band, maybe 3 to 4k max.
You could use something like a behringer 802 mixing board. It has a mic preamp, 3 band eq and phantom power if you use a condenser mic. That and a cheap karaoke mic like a shure sv100 or maybe a shure sm58 will give you a good sound.
Reactions: tuner and BBB
Here is a cheap $10.00 solution if you are good with a soldering iron..
http://www.w1aex.com/mic/mic.html
Check out this nice audio.
http://www.w1aex.com/mic/v3audio.mp3
http://www.w1aex.com/mic/AEXAM.mp3
Thanks 543 good stuff !
Yes. I have an 802 board and a sE-X1 mic to try some day when I get the time.
SEX1 mic haha,
https://www.seelectronics.com/se-x1-microphone
Reactions: tuner
Well this what I have so far ,
Shure SM 58
Art Tube Preamp
Behringer 7 band EQ
Art SCL2 Compressor
Hoping to get it working fine with a 148GTL
Then Adapt it so I can use it on the FT897D :)
Let us know how that turns out. I have a hunch that if you start running some big power you'll need RF shielded audio cables to prevent feedback. This became all too evident when I first tried the rack audio gear interface awhile ago. Guess I'll have to pony up for some more shielded cables and ferrites since the shack was "upgraded" ;)
When I keyed the 1st time the cones on my large pa speakers went full forward throw and shook the house prompting the wife to yell "what the *#&!@ was that?" haha.
Reactions: 543_Dallas
  • @ heartbreaker3473:
