*** Yagi 4-elements
azteca1304
Jun 4, 2006
8
what antenna would you pick up? maco M104C OR SY-4 FROM SIRIO. I like both, maco made in usa, sirio from italia
4 Ele Yagi LOOK AT MOSLEYS?
Hay go to the MOSLEY ANT web site and ck those bad boy cb
antennas out,you get what you pay for from these folks.
Paul-K8PG :D
read the post a mosely, but be prepared to spend the $$$$. or make your own which isn't all that hard. and if there is problems you can bit^h about yourself for making such a lousy product and how you should be fired for putting that P.O.S. out on the market and how you will never buy another one again :lol: :lol: :lol: 73 and good luck
go with the maco 104 take your time when building it there are a few tricks to do to the antenna that they used to put in the instructions when wilson antenna owned it. Maco dont put this info in there assembly instructions. just remeber dont over tighten any thing and put rope thru the element's this will help with viberation (no rope can cause viberation with in the antenna elements and cause the metal to get brittle and break) use lock tight on all bolts and coupler's and you should be good for a long time
hope this help's ya 73's
The 'problem' with 'SIRIO' is that they are just not built very much like a 'tank'. Won't/can't say anything about their performance, just that they don't 'do' well in tornados... or maybe it's the 'windy' content of the signal they radiate?
