D-104 >< IC-2200H....?
I gave up on this quest long ago, based mostly on what QRN just posted.
The D-104 is doing fine service on my TS-130S, and my 2 meter does just fine with the stock handheld mic. I didn't so much want a powered mic for 2 meters, I wanted a desk mic, and the D-104 was the only one I had at the time.
May I suggest you look for a Shure 444. It is non-amplified and should sound pretty good. I have used them with VHF commercial band radios and they work well.
Thanks QRN, I'll have to go mic hunting on eBay.....
I beleive Icom does offer a patch cable that goes from the ethernet type plug to a standard 8 pin, then you can run a desk mic that also has the up and down switchs to change memory channels.....
