palomar 400 high drive
I would try to keep the forward drive below 30 watts pep. You could drive it with a little more but it will damage the resistors used on the hi/med/low switch and will over drive the amplifier anyway.
No, thats not gonna work at all. Some one has swapped in a 2879 for a 3749 and thats not a good idea. Good luck with that one. I don't even think 3749s are correct.
" That would work if the 2879 is being used to drive the 3 other transistors."
Say what?? No such thing as a one pill driving three. Sorry.
That would require a very large wattage resistor to balance the output stage with the single resistor, cheaper to just add another transistor.lol
Schematics shown for this amp and I believe dwb showed us 2 show that amp using either sd-1446 or MRF455 transistors so obviously it has already been modified or is another version that we've not seen a schematic for.
Yea, I could have stated that different since a skilled person could build something like that. It seems as a general rule amplifiers have even numbers of pills at the final stage.
Bottom line on that Palomar is none of those pills were there when it was new. I did have a Galaxy 225 once that had two 3749's.
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
