Not unless the 3749's are a close match to the 2879, no it's not common practice to mis-match devices like that.this has 3-srf 3749 & 1 2sc 2879 does this sound right
That would require a very large wattage resistor to balance the output stage with the single resistor, cheaper to just add another transistor.lolNo, thats not gonna work at all. Some one has swapped in a 2879 for a 3749 and thats not a good idea. Good luck with that one. I don't even think 3749s are correct.
" That would work if the 2879 is being used to drive the 3 other transistors."
Say what?? No such thing as a one pill driving three. Sorry.
Similar to what a 6 pill has?I made a 3 pill one time with 3 1 pill sections like the 1 toshiba specs for a test circuit and combined it with wilkinson style combiners.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
