Dual MR Coily Enforcer Comp Setup
Oh?
Pics please.
(.uoıʇdo ǝ1qɐıʌ ɐ sı poɥʇǝɯ ɟo ʇno ʇıɥs ǝɥʇ ʞɔɐɯs ǝɥʇ ʞuıɥʇ 11ıʇs ı)
He doesn't have enough room on the roof for a bounce back set-up. Unfortunately he has already tried that with 10-Ks on tri-mags. Wasn't pretty either, of course.
I never knew that. :blink: Should have just centered up one of the 10K's and been done with it and good to go.
Wow.
Just wow.
Yeah, that has got to be the most ********** setup I have ever (maybe not the most) seen.
What's with the bungee cords on the right hand side?
Those 90* mounts don't appear to be the strongest especially in that configuration.
You didn't hear? The reason for the bungee cords is because the Star Gun mount's center screw that holds the thing together apparently stripped out and can't be tighten back down to hold the antenna up anymore...
DJ was driving down the Interstate dragging one of those $220 Coily's behind his van!:D
Another thing I found out, was the shop that installed the antenna's, and mounts tried to talk DJ out of mounting these antenna's in this manor, but since that's what DJ wanted, they did the work...Moneys, Money...
BAW HAW HAW!!!!!!!!!!!!!!!!!!!!!!
