Post Your Gear
Well here is my modest station
Rig on left
Icom IC-2200H ...antenna is a homemade j pole and MFJ swr meter
Rig on right
Icom IC 736 ...antenna is/will be a off center fed 80 to 10 meter windom and a Siltronix FS-600A watt meter
whats the blue box for in your mobil setup for?
It's not my set up; but I can tell you what it is.
The "Galaxy 350" is a linear amplifier. When one uses a stock radio with a small power output, one can add an additional linear amplifier to vastly boost the output power by using one. This makes the operator able to leap tall buildings with a single switch. Well; not exacly - but they can help extend the useful distance of the radio.
