70cm Antenna
Jaymom
Mar 14, 2011
67
Ocala, FL.
I just ordered a Yaesu FT-7900R 2M & 70cm transceiver. I have a J-Pole antenna for 2M and I'm not sure what to use for a 70cm antenna. Would it be possible to use the J-Pole? If not what do you suggest?
Have a blessed day,
Harold
Have a blessed day,
Harold
You need a dual-band antenna.
They do make dual-band J-poles, however, if yours is not one of them, then it will obviously not work.
It all depends what you want to do. Higher gain antennas are taller, and produce a low angle of radiation. To work well, they must be mounted 30+ ft above ground. Also, be sure to keep your coaxial cable runs short, and to use a high-quality low-loss coaxial cable such as RG8U, LMR400, or Belden 9913.
Obviously if you intend to work satellites, you don't want a low angle of radiation, you want more of a circular pattern.
Believe it or not, that 2 meter 'J'-pole will work 70 cm just fine. Expect something close to a 2:1 SWR, but that's not all that uncommon and won't harm that Yaesu at all.
Take the approximate center of 2 meters (146 MHz) and multiply it by 3. I get 438, which is pretty close to the 70 cm frequency. If you make a 1/4 wavelength ground plane for 2M (~19 inches long), it will be very close to 3/4 wavelength for 70 cm., like Doc said.
Odd multiples of 1/4 wavelength. Good thing to keep in mind for antenna work.
I'm experimenting Beetle. Love this hobby. Found a 70m J-Pole also.
Doc, I was told the same thing at our last club meeting. Waiting for my Yaesu to get here now.
Many thanks,
Harold
