Repeater Offset?
parttimehammer
112
Hey all,
Brand new to HAM, just got my callsign a few days ago. Curious about something with repeaters. I live in Socal and have found chatter on 147.090, which according to the internet is a Catalina Island repeater. I can hear them, but they can not hear me, even though some of the ones I can hear say they are using handhelds, like I am.
I am thinking that I do not have the correct offset programmed in. How can I tell what the offset should be? I was under the impression that anything in the 2m band is a 600 offset by definition.
Please help
The standard offset is 600 KHz but there are a few rare exceptions. The basic rule is that if the repeater OUTPUT is in the 146.XXX range then the offset is -600 KHz and if the output is 147.XXX then the offset is + 600 KHz. Again there are a few rare exceptions in the very low 147 range so if one offset does not work then try the other.
When you key the handheld it should read 147.690
Also, check that you have a tone set for the radio of 79.7
According to their website they "occasionally" us a PL Tone of 79.7
Catalina Amateur Repeater Association
Read your manual how to set a PL Tone or tell us what radio you have and we can try to help
I have a Woxoun KG-UV3D. I think PL is the same as CTCSS and I have a R and a T CTCSS setting.
As I understand it, offset translates the receiving freq to the transmitting freq when I push the transmit button, but I'm a bit confused on what PL or CTCSS *if they are the same* actually DO.
No, the PL and CTCSS is not the same. If you haven't, download the program for the Wouxun UV# radios, they're all the same program. Just makes it a lot easier to plug in the right numbers. You'll also need the programming cable and maybe a USB to 9-pin DIN converter. All that can be done from the front panel buttons but it's not exactly "intuitive"/easy.
try just having the offset with no PL tone at all and see if it keys the repeater.
If not set the PL to 79.7 then try the repeater
just make sure it displays 147.690 while you key the radio. Of course if it is not keyed it should display 147.090
PL and CTCSS use the same numbers. What makes them different is when they are used. PL when you transmit to open the repeater. CTCSS when you receive to open the squelch on your receiver. Usually the PL and CTCSS are the same if used. Sometime they need to be different (split) and some radios can't do that.
So how do you know what you have set on the radio? Varies by radio and on my Yaesu the display will show TONE if I am using PL to open the repeater. If the same location on the display shows TSQL then I have PL and CTCSS in use for transmit and receive. If neither are shown, but the + or - is displayed then I am in duplex mode and the repeater does not need a tone to open the repeater.
KE5MC, Mike
Ya, the transmit and receive freqs are correct.
How do I put in a PL code if they are not the same thing?
What is CTCSS then?
KE5MC, Mike
So you can have it set to T CTCSS which I guess would be PL and not have a R CTCSS for receiving it back? They do not always have to be matched?
Guys, PL and CTCSS are indeed the same thing. Motorola trademarked the name Private Line for CTCSS tones and it was shortened to PL tones instead. There is no difference in frequencies used nor whether they are used for RX or TX.
KE5MC think about the repeater's receiver. It has a squelch as well that needs to be opened up and it uses a CTCSS tone to do it.
Doc, you may be confusing CTCSS and DCS (Digitally Coded Squelch) which is different from CTCSS. A lot different.
Private line - Wikipedia, the free encyclopedia
Capt,
No argument from me on that point. I was just tying to layout a simplified explanation for a new users perspective. In my experience radio manuals play fast and loose with labels in the area of 'tone' between transmit and receive and while they are the same, in a sense they are different as explained/used in the manual.
Hopefully my efforts have helped and not muddied the water.
Mike
<snip>
<snip>
I think I understand what CTCSS tones are now, but how do I find out the correct tone when just scanning channels? Do I have to have the transmit CTCSS set in order for others on the freq to hear me?
What are DCS tones and how are they used? I have that option on my radio as well.
Thank you for all of the help and support, I really appreciate it, I hate feeling like a newbie
