Wouldn't end the outages, just require different circumstances for it to happen.I do not know why they do not put all power lines in conduits in the ground....that would end power outages.
Tim
Sent from my HTC Glacier using Tapatalk 2
Tim
Earthquakes and unauthorized excavation for a start . . .
Buried electrical lines are very expensive to install as they require special HV insulated cables as well as special work to be done to bury them or run them in underground conduits. While it may work in urban areas and sub-divisions it certainly is not even conceivable to do it in rural areas due to the extreme cost versus payback.
I respectfully disagree....they could do it......if they can finance a war with iraq for 10yrs they can put the power lines underground.....the power grid is antiquated....has not changed much since its conception.![]()
You are confusing federal money with corporate funding. The federal government does not build and maintain the power grid and all the distribution systems. Individual power utilities do that with a portion of their profits. To do the entire country would be ridiculously cost prohibitive. I stand by what I said.
However they get it done it needs to be done.....if the power grid failed in winter because of massive storms....millions would die.....the welfare of this nations citizens is in the hands of the government....not the greedy corporations....when it comes to something this serious...making a buck should take a back seat.....just like back in the 30s when roosevelt started the CCC's......you get it done for the good of the people and the country.
There is a difference between needing something and liking to have something. Try running interstate transmission lines underground. When one of those babies goes down millions are affected for up to weeks at a time. the big ice storm in Quebec in 1998 showed that. Millions of people that had underground utilities still had no power because the main transmission lines were down for miles and miles and miles. Again, it is NOT feasible to bury all the transmission lines. Repairing underground power lines is also more costly and takes longer. North Carolina did a study that found that while the incident rate of power failures was 50% less than overhead lines, the duration of outages was 58% longer. They also last about half as long as overhead lines with a cost of 8-10 times as much to install in the first place. If you want your power rates to more than double then it could be done but not in entirety.
http://www.sceg.com/NR/rdonlyres/465E6534-2FFB-4069-BF84-81465AEEF887/0/ Undergroundvs.pdf,
Those problems could be overcome....they just want to collect the money and not advance power transmission technology....if the weather gets more erratic....they will get caught with their pants down...and people will pay with their lives.
