New MACO BA1 Balcony Antenna
I don't even know how to work one other than keep turning the knobs until I get right. What is the tune and load for?
Maco 91 Antenna Matcher Tuner
Looks mainly. :laugh: TUNE and LOAD should only be on a tube amplifier and not a tuner. Usually it is labeled INPUT and OUTPUT like Palstar or R-TUNE and X-TUNE like the old Kenwood tuners or even TRANSMITTER MATCH and ANTENNA MATCH like Heath and others but never have I seen TUNE and LOAD on a tuner. They are simply variable capacitors that work together with a coil to create a variable impedance matching device that allows you to compensate for a bad SWR by making your radio see a good match even though you still have a crappy antenna match. Kind of like looking at the world through rose colored glasses. everything is still bad but you just don't see it.
Reactions: silly and Robb
Ok I checked on the Gamma match power limits and it will take legal limit or 1,500 watts no problem so thats great!!! **Jump_im**
Archer antenna matcher. It has no markings on which coax to hook up to which so-239
Fixed a broken solder tab that goes to ground on the matcher. It works good now and tuned in to the freq I'm using.
P.S. i got my K40 magmount on the roof cause I ain't putting my Vector 400 up til after I move
Where did you buy this antenna from?
I looked all over the net and the only company I found that had it listed is A-1 Telecom. They said I can't buy direct from them since I don't run a CB shop lol.
Maybe its just so new none of the other companies have added it to there websites yet.
I have an account with A1 Telecom and if need be I can find out shipping costs if you send me your zip code and if your interested I can have you send a money order to me for the amount and I can have them delivered or drop shipped right to your doorstep. I can also do a search and find another distrubutor if you feel better to order through someone else. Im also getting another of these for field day for our county amateur radio club.
I recieved my second AB1 Balcony antenna this afternoon now we have one for our Amateur Radio Club for field days!! I wont even have to look at the assembly instruction for putting this one together. Im going to assemble this one and get it all marked for easy re-assembly as I did for my other one. I cant wait for the club to see and play with this antenna.
Usually I contact a1 telecom by their email link with a request about a certain product and they email me back with a list of retailers
P.S. I checked on those retailers and they don't have it yet. Thanks Tony V225 for offering. I'll wait.
Going only by the descriptions (fighting 'stick') I would have to assume they were vertical antennas. It appears that they are proud of that machined tip... After that, it's just advertising.
How much are they selling for?
    boog351 has left the room.
