Most service manuals I've seen and used specify the recommended brand and model ("or equivalent").
Thanks for taking the time to answer the post, it's very helpful to me.
I'm on that road of building a bench and trying to learn.
Questions: Freq counter hookup, I have been reading some service manuals and it calls for the use of a freq counter.
I have had the kind that plug into the back of the radio, but what would you recomend and how do you hook it to the radio?
I just bought a clean BK model 1801 freq counter off ebay for $35....it looks like new and seller sez it works as it should and is accurate.....been looking for a while.....did not want to put a lot into one as I don't very often do alignments...bol getting what you need.
As of now....I have a....
Freq counter
Signal generator
DMM
Capacitor tester
Daiwa 801 watt/peak meter
dummy load
is a
fluke 87v multimeter
sufficient or should I be looking at something similar to a
Agilent 34401A
Really need a freq counter that displays 8 or 9 places. Because that will give you the necessary 10Hz of resolution that every freq counter needs for doing alignments properly. Most alignments procedures call for a +/- tolerance of 10Hz. Those Chinese units on eBay for less than $100 seem to be OK.
What kind of sig gen is it?
Model/make?
Do you have clip-on test leads and a RF Sampler?
Need them - too . . .
Its a ancient tube type heathkit.
I need probes for the B&K freq counter....and you have the kind that works with that unit.
That highlighted portion is the RANGE of the instrument; Robb's talking about RESOLUTION - not at all the same thing.
The spec sheet does show the resolution as "1 Hz" -- which I find a little hard to believe.
