Mobile amp wire size
Tripple Nickel
147
19
28
85
Monroe, Georgia USA
Wanting to know what is best size wire to run directly to battery for small amp in motorhome ? Would 20amp fuse be enough ? Any ideas where wire can be purchased already made up with ends for attaching to battery ? Any help would be appreciated.
555
I use 10 gauge straight to the battery @ 8' length with a 50 amp protection fuse at the battery with my kl503. Some will say 8 gauge but I've never had any issues with 10.
Get some good #4awg from a stereo shop and a good distribution block. The size amp fuse used is dependent on the amp draw that will be used, Some will say #4awg is over kill. But I would rather play it safe and have the larger wire. JMO. Make sure to use good terminal connectors as well and no-ox all connections as well. And also the ground should be the same size as the power and should be made as short as possible and go to a good ground point like a seat bolt. Again JMO. God bless and good luck.
All kidding aside, the guys can help you out if you tell them a few more things about what you are trying to do and what you have to work with.
You had to go and ruin it with a bit of common sense reasoning didn't you Jeff. :wink:
Seriously though we would like to help but without more info it's like asking how to instal a radio in a red car. :confused1:
