"It's not MOSFETS. It's transistors". I guess he forgot what the "T" in MOSFETS stands for. Apparently BBI stands for Big, BIG idiot.
Unregulated power supply=. So much for linearity and IMD performance.......WTF am I saying? This is an 11m amp. Linearity and IMD performance is merely a happy accident.
I'm curious. I'm not being a dick, I honestly want to know. I've seen you comment a few times the way you did above. Could you build a better amp that is practically priced and practical for a mobile application? If so how much and when can u have it done?
Sent from my SCH-I545 using Tapatalk
I am confused, I thought it was a Base amp we were talking about here?
You gonna run a inverter in the Mobile?
I am not going to waste my time watching the whole Vid, but you can clearly see the AC mains Transformer inside the case, Base amp.
You notice he is taking the amp readings at 120v ( could be more ) with 4 amps. What is the mobile going to pull with an inverter 40+? Not the 20 amps he mentioned. He will sell hundreds with this propaganda Also haven't RM been using 50 v devices on base amps for years?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
