Help
copilot
New Member
Jul 26, 2014
18
93
Northern Ontario
I am trying to start up my Realistic DX160 after a 25 year shut down. I went to start it up and installed a new ground rod and wire and run about 100ft. straight wire out in yard. But all it does is light up, no reception at all. Can anyone tell me what I should check. I sprayed the tuners but still nothing. I'm not to sharp at this. Al
OK, check for corrosion on the antenna connectors. I'm not really familiar with that radio so beyond that I'm pretty well useless.
I've not got a clue what that is, or where they are located. Any info you can give me would sure be welcomed.I'm just an OLD dummy at this. As for using the phones, the S Meter does not move off zero. Al
Don't worry about my problem. I hope I didn't make a mistake but I bought a used DX160 off EBay. I was told that it is working and I should have it in a week or so. Then I'll have the other for parts. Keep your fingers crossed for me.Al
Do you have a speaker plugged in? The DX160 does not have an internal speaker.
Also if you tune on the AM broadcast band does the signal strength meter move or show signals from a local AM broadcaster?
