New Forum... New Rig!
And have the AL80B hooked up now...
It's very nice. I am only running it on 110v for now, and seeing 1000 out on 40 meters. I have 220 ran now, and will convert the amp when time permits. It runs just barely warm when I'm jawing with the "locals" with 110 vac. I will drop the drive from the rig and try to keep output around 500-600 watts, but wanted to see what she'd do. My meter is not very accurate on the MFJ-989C, but I just ordered a Palstar AT2K today to remedy that and my troubles getting accurate tunes with the MFJ. After that, I'm pondering a heavy duty dummy load. My wife may divorce me if I spend any more money!
73,
Brett
Also, I've had quite a bit of on air help getting the audio right. I currently run the W2IHY 8 band eq and EQ Plus with a Radio Shack 33-3001 mic. http://www.eham.net/reviews/detail/5864 I get very good reports with it after adjusting both the W2IHY settings and making some adjustments to the internal parametric EQ. The FTDX-3000 will transmit 4k wide, but I've found the sweet spot for 3k and 2.9 as well. Nobody likes bass when DX'ing. :) I have also ordered an MXL R144 ribbon mic on recommendation from a good friend. We'll see if it outperforms my cheapo RS mic that I picked up for less than 40 bucks.
73,
Brett
I run that audio stack also :) I also use the iPlus for switching between rigs while using the same mic/speakers. It works great.
Reactions: 2RT307
Julius rocks. Best customer service EVER. I just use the switches on the back to switch rigs. A little cumbersome, but it works.
Palstar came today... already found the tuning points for it and it's working well. Probably going to put it underneath the rig since it's a tad bigger.
73,
Brett
Got the MXL mic in, and she's a sweetheart. Moleculo, here's a pic of the W2IHY stuff:
New mic that was supposed to be blue-ish/purple and chrome, but they sent me the special edition pearl white and gold since they were out of stock:
REALLY had to readjust the settings for this mic. I've had some very good on-air help with it, and seem to have it narrowed down to where it sounds very good.
73,
Brett
Hated the big hoop pop filter being in my face, so ordered a WindTech PopGard:
I like it a lot, and it doesn't block my view! Very light, so it doesn't weigh the boom down.
73,
Brett
Seems like a legitimate question to me, since bad seams would get oil everywhere.
On Edit: I guess I should have done a search... found Robb's old thread and your response:
"My Cantenna is so old that I'm sure it has the nice PCB goodness. It's starting to rust along the bottom and has a few war wounds. I got a new lined can with bail that's all shiny looking. I'm gonna powder coat it and change everything over. I popped the lid today, the old oil is nice and dark, looks heavy and barely has an odor. I guess it should be okay to use."
Mudfoot,Aug 22, 2012
I think I am going to get the MFJ one.. doesn't seem to be any difference between theirs and the Ameritron, other than the label slapped on the can.
73,
Brett
