No.The next director has to be spaced way out to get worth while result. Would have liked to go 8 or 9 meter boom and change all the spacing but that would have required changing the matching network and purchasing more materials.
I was feeling lazy and went with the materials I had on hand.
Was after minimum work and better front to back , previously had already maximized for 28.3 . I went with the model I had used to get what I wanted for 10 meters then added a director.Modeling with yagi cad I found the spacing and length that provided what I wanted without changing the resonance or radiation resistance much . Swept it after modification with the ant analyzer. Then using the analyzer as a rf source 100 meters away took rf readings and plotted a polar graph . The change in pattern was obvious with a much cleaner pattern.I'm very pleased with the results.
