Wilson 1000 or Stryker SR5 Antenna?
Galaxy 959
275
57
Arkansas
Will be running just a barefoot properly tuned radio. Whats your guys opinions on these 2 antennas? I have a K-30 now and a Lil Wil. I mostly use the K-30 now. Or if you have another suggestion I'd like to hear it also. Truck is a 2001 GMC Ex Cab 4x4. Because of my carport my antenna cant be no taller than the K-30 and I have it on my bed rail at the rear pocket on the drivers side. I chose the Wilson and Stryker because they screw off the mag mount and I'm sure they will have much better range. Thanks for any input.
From what I remember many people claimed that the Stryker was a re-badged Wilson. If it was me, I would leave enough coax handy, run the magmount on the roof then lay it into the box when you go into your carport.
Reactions: Galaxy 959
Yea that's a good idea. Would my current antenna perform better in the center of the roof? I've never tired it because of my carport situation. The SWR is pretty much less than 1 to 1.2 across all 40.
Yes it would and it would perform better with a fixed mount. SWR is not an indication of performance. A dummy load is 1:1 but makes a poor antenna. You will find the SWR goes up if you move it and/or use a fixed mount because the more efficient the ground plane, the shorter the antenna needs to be so you will most likely find you need to retune it a little although as long as the SWR is below 2:1 I wouldn't bother.
I would use a Sirio Hypower 4000 if you can get them in the USA. They're almost the same performance as a Sirio Performer 5000 but the whip is more flexible so the carport height restriction isn't an issue. I once took a Sirio 4000 on holiday to Menorca, Spain when I decided I wanted to operate 10m band. I put it in a suitcase coiling the whip up into a loop. 24hrs later I took it out of the suitcase and it sprang right back into shape.
Greetings:
If those antenna's are serving your purpose then continue to use them. Everyone's needs and experiences can and will differ. I believe that mounting them up on top of your pickup would help you. In most cases having the antenna up on top does turn out to be better. Again you would have to try it and see if it works out better for you given all of your requirements. The same goes for the exact mounting location. If the cab is well bonded to the frame then generally a central mount should work good. You may have to move it around though to find the sweet spot other wise.
Besides the 4k mentioned above, Sirio makes another antenna that you can lay down and it has a handy lever to do so. Linky below:
http://www.sirioantenna.com/index.p...id=180&zenid=d5535bfc1a6f6e0354046cdf56437a50
I do not own one of these myself, but have read many good reviews on them. I may try one in the future myself.
So while there are generalities and experiences we can share, we can't for sure say how a particular antenna will turn out for you, sometimes you have try them out. I have more mobile antennas than I remember now! Enjoy the hobby.
I suggest a sirio performer 5000. Wilson antenna are lacking in quality. Had a wilson 1000 go bad on me within a phew years. Bought a magnet mount sirio performer 5000. There are 3 ways to take off the antenna. Can unscrew it from the magnet. Can lay it down using the pivot point it has. Or can unscrew the pivot point joint and take the antenna off without having to unscrew it from the magnet. The performer 5000 seems alot better built. Good swr. Performs very well. May be a bit more expencive to buy the antenna magnet and the antenna, but seems well worth the money compared to the cheap way wilson is building there stuff. Had a bad wilson 1000 magnet sent to me.
The sirio pl145 mag mount will work with both the 4000 and 5000 models of the Siro antenna. The 4000 whip is longer and thinner thus the easier bending. Used one for a while and came back to the 5000 perfromer. Works well even with the mag mount, for a mag mount that is! Check out DNJ radio, I believe they offer a combo deal with the antenna and mag mount. Costs a bit less this way.
H&Y Has it for $111.81 shipped. Is that a decent deal or should I hold off. Its a package deal on there together. Thats the performer 5000 with the magnet mount 145PL.
    63Sprint has left the room.
