Forum HF Contest 12/13 Sept 2015
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,631
1,560
173
The Great White north
Good evening all. Here is the goods on the next contest.
Only contacts with other FORUM members count in the contest. The W9WDX roster maybe found as a sticky thread located herehttp://www.worldwidedx.com/threads/club-member-roster.132229/
-Frequency: HF 80 / 40 / 20 / 10. From top of the hour to the bottom for 80, 20. From bottom to top for 40, 10. For frequencies, forum frequencies 10 meters: 28.455 ( + ), 20 meters: 14.322 ( + ).
-Date/Time: 0001 12 - 2359 13 Sept 2015 UTC. If you're not sure how UTC time works, check here http://www.timeanddate.com/worldclock/converter.html?p1=3875
-Contacts: Contact logs may be in any format but it must be deciphered by common programs and must be posted in theW9WDX Contest Logs located herehttp://www.worldwidedx.com/forums/w9wdx-contest-logs.193/
Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest (if you wish). The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread.
At the end of the contest (+3 hours), the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
Contacts will be verified against each others' logs, non confirmed contacts will not be counted.
-Multipliers: 2x multiplier for mobile, portable, or maritime contacts.
3x multiplier for any contacts outside of CONUS and Canada.
4x multiplier for QRP. For this contest QRP is 10 watts or less.
-If you operate as mobile, maritime, or portable during the contest, you will be credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. Make sure you clearly designate these in your log
-Power limit: Maximum power 200 watts PEP
-This is an "on your honor" contest and intended to be fun. Please play by the rules
- BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
So is anyone planning on trying?? I possibly will on Sunday. Maybe even with my new semi portable setup which is an IC-7200 / LDG IT-100 and some sort of vertical.
in case i get busy today and not get a chance to post contacts.
12Sept15 W9FNB 14.326 20.18 B.J. 5-9/5-9
12Sept15 WD8T 14.337 20:20 RATSO 5-9/5-9+
13Sept15 W9FNB 3.865 "MOBILE" 09;30 BJ 5-9/5-7
got the contacts from "spotting myself" on the chat room(n)
will try to get some more this afternoon now that the honey do list is done for the day
OK thanks, no contacts posted for the weekend contest, but definitely enjoyed making contacts with other members of the forum(y)
  • @ Catalyst 122:
