President lincoln VER 3
RF limited 2018 extreme or the CR577 if you can find one. Not sure what you're after. Is it for base or mobile operation??
A turner plus 3 as Base setup would sound good I bet, post on what you end up running! I am thinking on pulling the trigger on one of those radios.
cheers!
Undertaker, I know the RF limited 2018 extreme has sounded good on every radio I've used it on including my HF radios. Never used the CR577 personally, but have heard they sound good as well. Another mic of you can find one might be the astatic 575. Those were some great sounding mics. I am sure the turner +3 would sound good as well but not sure how well it would work for mobile use. Those are 6 pin radios correct. Wonder what a stock magnum 257hp power mic would sound with one? Anyway, just some food for thought. Good day.
Reactions: rabbiporkchop
Thanks my friend. I have the 575 and a turner plus 3 desk mic. Guess I will just have to try and see..Yes I think they are 6 pin will check when I get home..
Reactions: 222DBFL
Can anyone recommend a good mic for this radio?
Thanks
Bobby
I would run an Electro Voice RE20 for a base and my trusty Electro Voice 602t
for my mobile.
Base
Reactions: 222DBFL
