Fine Tune CB
Status
Not open for further replies.
With my galaxy 959 sitting at the TA truck stop in the bottom of the canyon in Albuquerque New Mexico having a conversation with a buddy of mine at the route 66 casino over the mountain on the other side of the mountain at the bottom of the valley on the other side I can hear him just fine with a noise floor of .012uv and with my other galaxy 959 with a noise floor of .3 uv I had to drive further east up to the top of Sedillo Ridge to an altitude of 7000 feet in order to hear the same guy sitting in the same place. .
Pork Slice ... you are a LIAR. Plain and simple. The lowest form of life. There is no way in hell that you would be able to hear a station that far away while sitting in the TA in Albuquerque. The noise in a large metro area like that will cover up that guy like a rug. Not to mention the bleedover from drivers in the TA itself. Or ... does Mark's tuneup have some sort of secret magical "noise rejector" ???
The problem with liars like you is that once you're caught, you can never be believed again.
- 399
Corks?, we don't need no stikin Corks
images
The problem with liars like you is that once your caught, you can never be believed again.
- 399
I have no reason to lie. Once again I'll be more than happy to put your skills to the test and compare your abilities to the guy who built my station
- 399
Maybe the hi Q antenna that I use has a lot to do with the noise rejection. Keep in mind my antenna only needs to work on a single frequency. Also keep in mind there are two elements so it's very directional and cancels out noise coming in from the sides and increases what I'm capable of hearing front to rear
Those are your opinions but you are on record here as having said other's opinions do not matter so why should we be concern with your opinion? On that note someone above had the right idea. This thread has reached the end of it's intellectual capacity.
Status
