Snake oil or real deal, Perpetual motion machine?
Did ya also notice that the SOUND didn't change when more bulbs (the load) were added.................... DUH!!!
I was referring to the "Bhaskara's Wheel" on the editing jumps.
I think that 40 KW unit had additional wiring behind the board. There should have been a change in pitch as you suggested. There were not any controls to maintain the RPM's and if there was that's additional power input. "So you are correct Sir!"
Reactions: Road Squawker
Even more hilarious, if you look to the left of the load board you will see a section of Romex wire with the black and white wires attached to the load board with wire nuts.
Don't misunderstand me, I know it is a "wasteful" process. Just wanted to add something after a quote from wikipedia, about the "Brown's gas".. is all.
I guess I should have click-baited the title.
"CUT METAL FROM WATER" (and electricity)
And can do no meaningful work. Frictional losses will stop it the when a load is applied.
I went back and watched the video on full screen and noticed editing jumps. If you are trying to prove that a process is real, editing jumps destroy the credibility of the video document.
I do think tho that this idea could be used to make something to stick outside in the yard or a flower bed..."Yard Art"... I get board one weekend I might have to try and come up with something...
Reactions: Tallman
Maybe you could mount it on the massive antenna tower you have and make it wave a flag or banner of some sort?
