Coax Seal is excellent! I have been using the product for over 20 years with no moisture problems whatsoever.
BTW: Why is your antenna mounted on the ground?
Yes Sir! When I first decided to get back on the air after a 28 year absanance I left a post asking that question on this very site (wwdx radio fourm) wheather a non penetrating roof mount would work for mounting my antenna on the ground in my backyard? The consensus was absolutely!
My second question in that same post was would my antenna work at only 10 feet from the ground?
The answer to that question wasn't as positive. Some said it would work. Some said it wouldn't work. And some said if it's all you can do in order to get on the air go for it and see what happens.
I followed the advice of the latter and my a99 had an swr of 1.3 with 2 Watts and 1.5 with 1K.
I've talked locally 70 miles, and when conditions were running wild I made contacts and held qso's from Japan to Turkey, and Alaska to Brazil.
It was either that or stop looking at the old gear I'd collected since the late 70s, and stop dreaming about getting it on the air again.
I remember thanking everyone who told me to go for it and see what happens. As a matter of fact I recall several other replies stating they've operated a 99's and 2000's mounted less then 2ft off the ground. One guy on a Caribbean Beach, during vacation used about 4 ft of bamboo pole shoved in the sand, and it worked like a charm.
I would like to have the antenna higher in the air but with that comes guy wires, and my backyard isn't that large. We have barbecues during the summer and my nieces and nephews do lots of running around. We also have the occasional deer strool through. Guy wires coul injour or possibly kill the animals and worse the children. Getting cloths lined buy a guy wire can be detrimental to your health.This non penetrating roof mount is normally used for those who have a flat roof and don't want to or can't use screws in order to mount a tripod. They also sell one for a pitched roof.
The first (brown colored mast is part of the n.p.r.m and the one above that is a standard mast I added. The antenna although not seen in the picture is mounted on that one. My antenna I actually less then 10'. More like 8'. This is what it looks like before adding the cinder blocks, another mast and antenna. Thanks. 73's
