Frequency counter hook up???
Flyincoyote
Jan 28, 2018
36
16
18
45
Minnesota
Does anybody know how to hook up a frequency counter...i bought a cheapy chinese freq counter..put a bnc to pl259 and plugged the coax from my radio to counter??? Nothing started smoking...but had crazy frquency fluctuation
Ok thanks..hope the counter isnt fried..i have the scematics for the radio, ill try to find the heterodyne
Take a 3-4 inch piece of solid 12 ga copper wire, wrap it 5x times around your radio's coax, and then connect each wire of the freq counter input to each end of that coil. Tape that coil to the coax with electrical tape so it doesn't get unraveled or let it move around. It will get the signal to the freq counter by the principle of INDUCTION.
Hope you didn't already fry your counter . . .
Take a 3-4 inch piece of solid 12 ga copper wire, wrap it around 5x times around you radio's coax, and then connect each wire of the freq counter input to each end of that coil. Tape that coil to the coax with electrical tape so it doesn't get unraveled or let it move around. It will get the signal to the freq counter by the principle of INDUCTION.
Frequency counters are not all created equal.
Finding out what you have would go a long way towards figuring out the best way to make it work on your radio.
Then again, if it's the kind that should hook to the inside of the radio, it would help even more to find out what kind of radio.
Reactions: Flyincoyote
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
