Base IMAX 2000
In the clear is always best but many of us have limitations where are antennas are.
Consider this, Many of us use trees to hang dipole antennas from.
Reactions: BJ radionut
Undertaker , I'm sure you have posts on here that tree's don't make a difference , I thought the same . Recently I had 8 huge oak trees taken down ( My XYL's deal ) . Wow what I difference my receive on my A-99 has improved almost 100 percent
and my output I get compliments on . Local Op's think I'm running my new amp I'm not ! Just my barefoot Cobra 2K , I save the amp for " Good " Dx . JMO
If I mount this antenna by a tree will it hurt the performance?
I can't say how much it would affect the performance you would have to mount the antenna 30 or 40 feet away and then have a way to test the idea with another station far enough out to give you a result that you can say is based on it being real close to the tree and 30 ft away from the tree. But if you mount it to close to the tree you could give the tree brain cancer? Sorry, could not resist a little humor.
Even a couple of wavelengths apart can still cause some interaction. 1 wavelength should be fine.
Why 2 verticals?
Undertaker , I just checked Sirio 27-4 beam is @ $150 . I paid less than that over a year ago , but mine is still in the box because of no help to put it up . I had the rotor and box already and the eave mounts are on my house from an old Tv antenna . I'm not going that high because of my elevation ( 30' to my peak of roof ) but a little more $'s you could be Sweet ! Someday I'll find out !:LOL: Jmo 73 and God Bless , Leo
Reactions: undertaker
