Receiver alignment measuring audio watts with what???
Hello. I am starting to experiment with a VTVM meter. The model is the KYORITSU K-1420. I have no idea how it should be used for adjusting the RX coils of CB equipment. I have read in most manuals that injecting with the generator a signal of 108dbm at the frequency of 27.205MHz CH20 at a tone of 1KHZ. Connect the VTVM meter to the external speaker connector. But I can't get movement in the VTVM needle. What mode should I use AC DC- DC + OHM? Let's see if someone can point me to the right path. Since now I only use the smeter method for that adjustment, but when I have to do it in a digital meter ...
