SBE Console V, Cobra 2000 GTL or Tram D-201 Which One
NightThumper
South of Pittsburg
Nov 8, 2017
655
1,555
153
Looking to pick up an older/vintage 40 channel am/ssb base station. The following opportunities have presented themselves. I’m asking the brain trust for their advice. Extra channels not a criteria that’s what my RCI 2995 DXCF is for.
1. A 9 out 10 SBE console V recently re-capped. Very Nice
2. A Tram D-201 a 9 out of 10 cosmetically. Working good, again very nice.
3. The classic Cobra 2000 GTL a 9 out of 10. Very nice.
Price is not a factor.
Thanks
Brad
I'm partial.
Thanks
Brad
I would take the TRAM any day over the others.The tubes will give you far better rejection across the band over the solid state radios.It is also works great on AM & SSB & has great transmit audio.If you lived in Florida or South Georgia you could come take a look at my TRAM D201A that I am selling but I will NOT be shipping it anywhere.It is a CASH Pick up item ONLY.It's a great radio but I never use it when I am on 11 meter since I use my Golden Eagle MK IA on AM & my DAK Mark X on SSB 99% of the time.Ham Operator for just over 25 years & on 11 meters since 1965.
SIX-SHOOTER
Out of the choices available I like the Console V. They all put out the same power on the same frequencies, so there's no technical preference.
I just like the looks and audio.
It just depends on what you're wanting out of the radio, whether it's looks, or functionality.
For ease of maintenance, easy modifications, while still sounding great, Cobra 2000 all the way. The Console V is a great radio if it's already been serviced, as they are known for solder joint issues due to the double sided PCB. The Tram D201A would look great on the shelf, but wouldn't be real usable, as they are a high maintenance radio, and the channel selectors have a very high failure rate.
Worked on all 3 many times, and that's my take on them. :)
~Cheers~
Brad - congrats on being in a position to make this choice. Either of those 3 radios would look great on your radio bench.
Over the years I've owned a couple of Madisons and enjoyed them but never managed to have a 2000. So the 2000 is my bucket list radio. But since locally the SBE radios aren't very common that would also be very tempting.
Reactions: 357magnum
Used to have a Cobra 2k many years ago, everyone always said it was a good clean sounding radio. It also had more extra channels than everyone else around me had, unless you had 10m export.
Wishing I'd never let that one slip away.
in order of difficulty to find parts for, expense of repair, and amount of problems inherent in the design, the list from best to worst goes like this:
1. 2000GTL
2. SBE console V
3. Tram D201
as for performance, the SBE has a better receiver than the 2000GTL.
I have never owned a tram so can't speak to their performance.
after that, it's cool value that counts, and only you can determine which one you'll feel coolest using.
Not all Cobra 2000s are created equal.
The 1978 model needs to have some factory updates applied if they haven't been already. It will be old enough to need a bunch of electrolytic caps replaced. And the mileage that's on a 40-year old radio is important.
The 1993 model is just beginning to reach that "awkward age" when electrolytic caps can be expected to croak from age and mileage.
But the spread from worst (1978) to best (1993) is pretty wide. Too bad they don't come with an odometer so you can read the mileage.
Low miles always work in your favor, whether the radio is 26 years old or 40 years old.
