Mobile Which mobile vehicle model here performs the best?
Which mobile model would you pick as the best performer?
  • Total voters
    20
Marconi
Honorary Member Silent Key
Oct 23, 2005
7,230
2,391
343
Houston
Over the last few years I've made numerous mobile designs using mostly 102" whips as the radiator. In my case I have a limit of 500 segment per model and the mobile body can require 1/2> of the 500 segments just for the body alone. So, I'm limited in making mobile models if the radiator is complicated by having a coil. Coils can require many wires and each wire has 1 or more segments. It all adds up, so I stick mainly with a simple whip antenna.
Recently I checked several models I had made using various vehicle brands and shapes. I was surprise at the results when comparing the following mobile objects I had created when I added the radiator to the models. I was curious how different vehicles might compare.
1, the first model I ever made was a Blazer sent to me by Henry HDSP, a member on this forum. He is in the Netherlands. The model he sent me was a small vehicle that basically looks like a PU truck. It had no metal covering over the top of the back...like a real Blazer. The whip antenna is in the center of the cab and the feed point sits at 66" inches above the ground. The Blazer is 15' feet long overall and about 72" inches wide.
2. is a standard length PU Truck that is 15' feet long, with a 1/4 wave radiator in the center of the cab at 70" inches above ground. All models are set 72" inches wide.
3. is a Suburban with a 1/4 wave radiator that sits at 88" inches above the ground. It is 17.5' long. I made this particular mobile design based on a similar design created by The DB here on the forum. Here we made our mobile model object with far more wires, as noted. I'm just guessing, but I think DB made this model to see if a more complex mobile object, with more wires closer together, would result in a better and/or more accurate model.
4. the last model is my original SUV model that is about 15' feet long and 72" inches high above ground.
The Suburban and the SUV models were positioned as close to the center, length-wise, as necessary to make the patterns...as symmetrical as possible from front to back. The PU Truck and the Blazer are in the very center of both cabs.
The 102" whips for all models were adjusted to length at resonance.
I will post these models after a few interested folks vote.
Below in the PDF file titled, "Mobile models compared" are the full model details and results.
Not that many people put a full size 1/4 wave on the roof of a P/U truck or SUV. Why not go for a more realistic mounting location like on the rear quarter somewhere or a smaller antenna on the roof? I suppose however everything is relative as far as patterns go as a smaller antenna will have the same horizontal pattern but just lower gain. Might want to try different mounting locations however. I have my antenna mounted on the rear corner of the box on the drivers side of my Tundra Crew Max. The truck is 18 feet long with a short 5 1/2 foot box but LARGE cab area.
Marconi , is this a trick question ? You holding out on us ? Waiting for the results Oh Antenna God ! :whistle:;) 73 & God Bless , Leo
No Leo, I was reading a current thread about members opinions on which mobile antennas folks considered to performance the best.
In my experience, I found most base type vertical mono-pole CB antennas perform pretty similar...if the antenna tips were close to the same height.
So I wondered, what my Eznec models might predict if I compared the influence of the vehicle style and shape for a mobile antenna setup...instead of just changing the antenna or trying another brand or design.
Reactions: 357magnum
No vehicle is better, all mobile installations are a compromise anyway. More and more plastic means less and less ground plane available.
True, but this was not a problem solving idea.
By now most of us probably have some ideas about the problems with modern vehicle construction being problematic for 2-way RF installations.
These models have limitations as well. I can't be sure this is exactly how a real mobile will work with the model's vehicle body being made up of a bunch of small wires...instead of a smooth contiguous surface of good reflective metal.
My simple point here, was to show what these Eznec models show that the body shape and size can possibly make more of a difference than most might imagine. I was surprised.
Ease of installation is my main concern. Of course the more metal the better. I’ll pass on any small VW Beetles or fiberglass sports cars. The important question in my mind is how easy it will be for me to install a roof mount. Some vehicles have easy access to the roof under the dome light without any major obstructions, others are difficult with cross supports at the desired locations. Removing headliners without damaging them becomes another issue. To immediately evaluate these possible problems, my particular favorite is a full sized commercial van that has a stripped down interior. For a full fledged communications van I want a vehicle with no fancy headliner or side panels. Those details can be added later after all the holes are drilled and wires routed. That way the curtain is pulled back revealing all the mysteries behind it.
CK, this alone was complicated enough. Sure other configurations will make for different results.
I was going to add a model that I use to run, a 102" whip on my 1993 Chev long bed PU truck. It was mounted in the center top of the tail gate. As a note, back then I never considered bonding that tail gate to the body of the truck and it worked great when I was pointed in the right direction.
Sunbulls, I don't think I can question any of your points.
When I compared my Eznec models for these vehicles noted...I was surprised at the results.
I too, always figured the Van like you mention and the Suburban/Explorer type body designs were just as you are likely suggesting, the best performers. The bigger and flatter the roof as the ground plane in a mobile...the better.
These models just don't show that.
