Bump for someone that was looking for plans. Use at your own risk. Additional work might be needed.
Welcome!I just registered an account for thanking all off you posting and reposting those plans!
Greetings and love from Germany!
Leon.
55+73
Welcome!
Here is one place, I'm sure there are more.The next Question would be where I can get the 1/2" x 1/2" or 1/2" x 2" Ferrite Cores and the HF Transformer![]()
It's interesting that the 27 MHz. test circuit really appears to be a broadband HF circuit...usually 43 for the input transformer and 61 for the output @ 27mhz
YMMV
The attached pdf has a parts list for a 27.120 ISM and lists Fairite #61 for the output.
thanks you because of this im almost done with my 16 73s1 pill
No problem, do you have any pictures of it?thanks you because of this im almost done with my 16 73s
