Larsen NMO-27-C testamonials?
Has a slick commercial flair
Needs a happy face? Disney logo?
Unlike the menacing appearance of the tax-dollar-being-used-against-you Larsen?
Dog dish hubcaps on blackwall versus full covers with whitewalls? Biscayne versus Caprice? I6-250 versus V8-427?
Hell, just mount a Rebel Flag Connex inside.
(Quality of photo and final processing is the giveaway).
Reactions: WECSOG
If a vinyl shrink-tube was applied to a polished chrome or stainless steel antenna, would the antenna still function?
Sure it dont see why not. If your referring to what we call shrink wrap. I had a buddy that was worried about water getting in the joint 1/2 way up a vhf/uhf vertical base antenna. He shrink wrapped the entire thing from the radials to the top... worked fine.
Reactions: Groundhog KSS-2012
Yes, I am referring to the material used by electricians to cover a spliced wire connection. A heat gun / hair dryer is used to apply the shrink tubing / sleeve. For the folks (like me) who don't like the chrome bases on mobile antennas, the coil / base can be covered with the black shrink tubing.
Larsen works fine for barefoot radios - I would never run an amp with one. Rated to 200 watts which means I wouldn't run more than 100 watts through one. I usually go the 50% route to be safe since antenna wattage claims are usually BS.
The instruction / guide sheet with the Larsen was a good "guide" for trimming the antenna for 27Mhz. The antenna was 49" long and the instruction sheet recommended a length of 47" for a roof mount installation without a spring and a length of 46-1/4" with a spring. Being that the antenna is attached to a Third Brake Light Antenna Adapter, I wouldn't consider the antenna to be classified as a "roof mount" installation. Starting with the original 49" long antenna, I trimmed-off 1/2" pieces until the SWR was down to 3 and then I trimmed-off 1/4" pieces until the SWR was below 1.3 on all channels, being 1.3 is on Ch. 40, 1.1 on Ch. 1 and 1.2 on Ch. 20. I'm done! Final length is 46-1/4".
Next task is to compare the transmit and receive of the Larsen and the Browning BR-140-B.
I think it was around 49" or so but I had to cut it down quite a bit during tuning. I took a good 3 inches off.
Doesn't look to bad actually and the performance surprised me. I definitely would run any power through it. Rated for 300 watts but I bet anything close to 100 and it will start to get warm.
The length of the Larsen was also 49" and after trimming-off pieces to obtain a 1.1 to 1.3 SWR, the final length is now 46-1/4" and the final length of the Browning BR-140-B is 46-1/8".
Reactions: Slowmover
Now I know why mine would not tune!!! Guess im gonna have to do some trimming
The "trim chart" which came with the Larsen has a roof-top mounted NMO27B / NMO27C having a trimmed length of 47" without a spring and 46-1/4" with a spring for 27 Mhz. I do not have a spring and the SWR is great at 46-1/4". Go figure! My first cut was 1". I had to remove the black paint / coating to ensure the antenna was fully inserted into the socket before checking the SWR. I don't know if it makes any difference, but I always file the cut-end as flat as possible after I cut the antenna with pliers so as to get that warm and fuzzy feeling that the bottom of the antenna makes good contact with the socket.
For CB, I use an Larsen NMO-30 coil, 3 inch spring and I believe. a 60 inch whip trimmed down to around 56 inches or so. Has decent bandwidth. I really like it. I think it's better than any Wilson. But it is limited by power. I dont run POWA, so it works for me. It's sexier, too. I copied it from some dude in Canada that posted his results. I have an NMO-27 CB antenna, but I don't much care for it.
At first, I ran it hard mounted. I use a 4 inch mag mount with it now.
As per Larsen's Trim Chart, the operating range for the NMO30 is 30.0 MHz to 35.0 MHz with antenna lengths from 35-1/4" to 51-9/16". What is the length of your antenna with the NMO30 coil? I am curious if all coils are the same and only the antenna length is different.
Save the file.
Given the picture posted of, Recon’s Dog, I’d imagine that son-of-a-biscuit could make it shark-bite clean.
    63Sprint has left the room.
