advice on groundplanes please
david megone
New Member
Jan 30, 2020
hi i am after some advice on wether putting a full size 1/4 wave groundplane on my thunderpole 5/8th wave antenna with 12 inch radials would improve the antenna
I tend to keep it simple. I like maco 5/8 ground plane and for $100 or so you cant go wrong. As far as a Frankenstein antenna, I cant really help there but im sure someone here can.
He's asking about this antenna.
If the gp wasn't in the original design then I don't see any improvement in adding them. But then again, it doesn't hurt to try it just for grins. If you do, let us know how it works.
(y)
Physics would like a word with you. The reason CBs got a reputation for causing TV interference was precisely because of a lack of ground planes.
Not necessarily.
If an antenna is installed correctly with or without a ground plane, it should NOT cause TVI.
This is all I'm posting on the subject...
I'm out. Have a good weekend.:)
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
